| | | Forums66 Topics128,089 Posts1,056,433 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | 75/25 is what I use for everything MIG. I adjust my technique to compensate for the differences in thickness. If you use an Easy Grind wire like Lincolns SuperArc L-56 (.025) you can't really get any better. The nice part about adjusting your technique to compensate is you can use 75/25 and .025 wire on everything there is (mild steel). On the thick stuff like hitches, double pass welding techniques, on thin stuff like what I am doing now... http://forums.devestechnet.com/foru...0-tip-of-the-week-38-for-june-19-25-2016Cut the power way down, wire speed way down, keep the welds clean and skip to the coolest part of the panel with about 1/4" stitches each tack, and you are good to go. A very handy vocation to learn for all ages and you can do it on a Lambo or an old Chevy truck with the same great results. | | | |
Entire Thread
Sheet metal welding, which kind is best?
| beltfed | 06/22/2016 11:31 PM |
Re: Sheet metal welding, which kind is best?
| Hotrod Lincoln | 06/22/2016 11:45 PM |
| Deve | 06/23/2016 12:11 AM |
| beltfed | 06/23/2016 2:45 AM |
| Hotrod Lincoln | 06/23/2016 3:37 AM |
| 52Carl | 06/24/2016 1:52 AM |
| Deve | 06/24/2016 2:35 AM |
| showkey | 06/24/2016 1:55 PM |
| bartamos | 06/24/2016 9:08 PM |
| 52Carl | 06/25/2016 3:50 AM |
| beltfed | 06/25/2016 2:05 PM |
| bartamos | 06/25/2016 7:30 PM |
| beltfed | 06/25/2016 10:43 PM |
| bartamos | 06/25/2016 10:46 PM |
| Hotrod Lincoln | 06/25/2016 11:15 PM |
| Deve | 06/25/2016 11:54 PM |
| Don | 07/07/2016 5:27 AM |
| Allen Lane | 07/08/2016 1:07 AM |
| thoroco | 07/08/2016 10:13 PM |
| Allen Lane | 07/09/2016 1:23 AM |
| thoroco | 07/09/2016 4:03 AM | |
