0 members (),
112
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | For one thing try to find a place that is easy to get to. personally I think one before the fuel pump is good. Since I can get under my panel fairly easy I put one just after gas comes out of the tank. I've seen many filters before the carb and have one like this on my V8. There is also a filter that Screws into the carb which would help eliminate a hose or clamp malfunctioning and causing problems. Ultimately, the choice is yours. Is your tank in like new condition? are you lines new? All these play a part in decision making.
One last point. If anyone's tank is located where it can gravity feed I'd recommend a cut off valve there for safety. | | |
