I've got to ask this question....on the AD reproduction light switches I've seen have information stamped on the face/back of the switch. I just changed my switch on the 52 panel last night and it is labeled at each post......but it is hard to see.
...but the repop's for the 46 may not show that??
If your 12V and using this repop switch #EL60 from Carter you an see the labeled post. Click on the image to make it bigger.
http://www.oldchevytrucks.com/cart/index.asp?cat2=9764&path=1934+%2D+1946+Truck+Parts%2FElectrical%2FSwitches
