| | | Forums66 Topics128,274 Posts1,058,425 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,949 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | If you're going to make that much of a change of the pedal stroke, I would strongly advise adding an under-floor power booster. That will allow much better stopping ability in case his leg strength is also compromised. Also, if a conversion to disc brakes isn't on the menu, at least figure out a way to install self-adjusting hardware to keep the pedal height up near the top. That isn't a terribly difficult conversion to do.
