Brrrr
place holder
3 members (TexasFarmTruck, Wayne67vert, Otto Skorzeny), 73 guests, and 3 robots.
Topics128,274
Posts1,058,425
Members48,485
Hi..we have a person in our family with a leg disability. He cannot drive his fathers 1954 chev 3100 truck as the brake pedal extends too far into the cab and he cannot lift his leg that high. They asked me to cut three inches off the pedal shaft and reweld the pedal plate back on. They say there is enough travel that the pedal will not bottom out. I told them as the brakes wear the pedal will get closer to the floor board. Is there a better way to shorten the stroke or is removing three inches ok. The truck still has its single MC and they want to keep its originality......id like to see the young man drive his dad's truck so any ideas would be great.....thanks, Steve
If you're going to make that much of a change of the pedal stroke, I would strongly advise adding an under-floor power booster. That will allow much better stopping ability in case his leg strength is also compromised. Also, if a conversion to disc brakes isn't on the menu, at least figure out a way to install self-adjusting hardware to keep the pedal height up near the top. That isn't a terribly difficult conversion to do.
Riding in the Passing Lane
Ive cut mine down about 2 in. enough to match the clutch on every truck ive had. It is much more comforting to drive & looks better too. If you adjust the brakes occasionally it works fine. I agree if a guy has weak legs power brakes would help.
1972 Chevy c10 Cheyenne Super
That's about right the brake pedal is higher than the clutch just like you described ..why....they wanted to take three inches off but you cut two with no ill effect. The lad has tremendous push strength in his leg his birth defect is the knee and having to lift it at such a weird and high angle it's tuff it's just not lift but it's moving your leg at an angle and lifting from the gas pedal. Perhaps we could start at two inches see what happens. Your fix sounds just right line up clutch and brake pedal for smooth movement. We all need help sometime....
