| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,837 | Check the turning torque required to turn the pinion gear with an inch/lb. torque wrench. If it's not above 20 in/lbs. or so there shouldn't be a problem with a slight amount of extra pinion nut torque. Jerry
