| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Installing the engine/trans as a unit with the front end sheet metal in place is a real challenge. That's why most folks move the trans back a few inches and support it on a jack or wood blocks while getting the bellhousing down onto the crossmember, then install the transmission. Good on ya for being persistent! Jerry
