| | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy John Gobby, I have never before read the term suicide master, I assume it is referring to the single system brake master cylinder. The fact is hundreds of thousands of vehicles ran around for decades with this type of braking system, and I don't recall seeing headlines in the papers every morning about the horrible accidents caused by this braking system. That being said we have the option of upgrading that system to a dual master cylinder braking system giving us one more layer of protection against accidents. For vehicles such as yours with a hydraulic clutch and having the brake master cylinder and clutch master cylinder in a common casting, converting to a dual master braking system can be a challenge. I am glad you found something that will allow you to convert to a dual master cylinder braking system. Now to track down the part you referenced so that I may educate myself. | | |
