4 members (55shaker, IHPWR, Otto Skorzeny, 1 invisible), 76 guests, and 2 robots.
Topics128,026
Posts1,055,403
Members48,422
#1132788 11/04/2015 2:12 AM
Hi all. I have a 62 c30 with the suicide master brake cyl.I've seen an ad for a replacement with two masters and a booster for the brakes. Does any one have an opinion on these units
good planning is no substitute for dumb luck
panel fan #1132826 11/04/2015 5:03 AM
3B Offline
Hy John Gobby, welcome, could you post a link to the ad you saw please? Does or will your truck be equipped with a standard or automatic transmission?
panel fan #1132862 11/04/2015 5:04 PM
Hi shop shark, I found the unit in a L M C truck parts catalog part no. 37-8558. I just replaced the sm 420 tranny with a T5 witch works great so the truck will remain standard.
The brakes are the original set up, drums and no power assist witch work fine but i'm not anxious to find out how they came up with the suicide moniker
JOHN
panel fan #1132966 11/05/2015 5:06 AM
3B Offline
Hy John Gobby, I have never before read the term suicide master, I assume it is referring to the single system brake master cylinder. The fact is hundreds of thousands of vehicles ran around for decades with this type of braking system, and I don't recall seeing headlines in the papers every morning about the horrible accidents caused by this braking system. That being said we have the option of upgrading that system to a dual master cylinder braking system giving us one more layer of protection against accidents. For vehicles such as yours with a hydraulic clutch and having the brake master cylinder and clutch master cylinder in a common casting, converting to a dual master braking system can be a challenge. I am glad you found something that will allow you to convert to a dual master cylinder braking system. Now to track down the part you referenced so that I may educate myself.
panel fan #1132996 11/05/2015 3:54 PM
Seems it's mainly a set of brackets such that a single clutch master cylinder is fit in about stock location. Then hung out in front of the clutch MC so it clears is a vacuum booster and brake MC. Nothing real fancy or special, just a pretty straight forward solution.
1952 Chevrolet 3800 pickup
---All pictures---
Moderated by  Dusty53
