| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,949 | Be sure you center punch the broken-off bolt dead center before you start drilling, as you'll only have one opportunity to get it right. I've seen untold numbers of damaged threads from getting a drill bit very slightly off-center when trying to remove a broken bolt. Jerry
