Well I did it. I just purchased the 59 Apache 32 Fleetside I've been looking at. 350,funky p/s,p/b,4 speed,4WD w/np205 transf. case!!(#'s from plate on tranfer case: Model 205, ratio:196,ser.#4275, assy.# 3987901) I have to try to figure out what tranny it is (granny low - orig.?), and what the motor came out of, and what the axels are from. Seller says at least some of it is '87 Blazer. Anybody know what #'s I need to look for? or a good book to look up this stuff in?? The plate on the drivers door pillar says trim:RPO-258A paint:RPO-731J, and by the VIN I know it was built in Kansas City. I would be grateful for any info, Norse helped a lot already when I was still hemming & hawing about it. I would put up a pic or two but don't know how to do that... also with the truck igot an odd looking part - I think might be PTO related?? it is stamped with the word Eaton, and has three fluid ports and an input(?) shaft, :confused:
220 - 221 whatever it takes
