2 members (Stewart2, 1 invisible),
58
7
Mod | | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 110 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 110 | I grind the weld, paint all the parts and bolt them together, making all the checks to make sure the tail gate will fit right and then scrape the paint at the weld and tack weld the spots with my wire welder. Then use low pressure to touch-up the welds. Or you could use a small brush. The spots are in an area that isn't noticable anyway. You do need these welds or the bed sides will slip and get wider at the top. Hope this helps.
Truck Tinker | | |
