Hy Gene_Spartan80, Is this carb a manual choke or automatic choke? It sounds like the carb should have a total rebuild, and a check of the power valve and all circuits. There could be many marginal conditions on this engine causing different symptoms, but we have to start to correct everything somewhere and the carb is as good a place as any to start, hope that helps.
