Curious about the axle mounted R&P. It has to have a slip joint in the steering shaft. Does the slip joint have a grease zerk or does it have some type of plastic in it? I would think the shackles and spring eye bushings would need to be in good shape to keep the shaft aligned to the slip joint. Once I used a Toyota box I've never considered anything else.
Evan
