| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,755 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,755 | Good detective work! I see you're dealing with a late model 235 without the dippers on the bottom of the rods, so the pan should be pretty open. Earlier engines had a trough under each rod for the dipper to dunk into. Scrape out as much crud as you can from the oil pan then grab a stiff-bristled parts washing brush and some solvent like kerosene, mineral spirits, or one of the water-soluble cleaners, and give toe pan a good scrubbing, inside and out. Follow up with a pressure washer or take a trip to the local coin car wash for a pressure blast with the tire cleaner/engine degreaser. Some car wash managers frown on this so I usually do my engine block and cylinder head cleanup LATE at night!
There's a really good way to use the engine itself as a degreaser for the crankcase- - - -after reinstalling the pan, fill the engine with cheap 30 weight oil, and add 2-3 quarts of kerosene or Diesel fuel over the full mark so the crankshaft is whipping into the oil/solvent mixture. Run the engine at a fast idle, maybe 1,000-1,200 RPM for about 10 minutes.
DO NOT DRIVE THE VEHICLE OR PUT ANY LOAD ON THE ENGINE!
The crankshaft will do an excellent job of splashing the solvent around, and if you drain the crankcase while the mixture is hot, the sludge will drain out with the oil. Refill with your usual engine oil, change the filter cartridge, and drive on! Jerry
Entire Thread
235 engine noise, help needed!
| KeeneBolter | 01/02/2015 6:37 PM |
Re: 235 engine noise, help needed!
| VEW | 01/02/2015 6:57 PM |
| blanch53 | 01/02/2015 7:07 PM |
| KeeneBolter | 01/02/2015 7:10 PM |
| don stocker | 01/02/2015 7:34 PM |
| truckernix | 01/02/2015 9:03 PM |
| KeeneBolter | 01/03/2015 12:44 AM |
| MikeE | 01/03/2015 12:57 AM |
| Hollow65 | 01/03/2015 1:41 AM |
| Hollow65 | 01/03/2015 3:06 AM |
| don stocker | 01/03/2015 2:29 AM |
| Hotrod Lincoln | 01/03/2015 2:45 AM |
| KeeneBolter | 01/03/2015 2:52 AM |
| Hollow65 | 01/03/2015 2:57 AM |
| Hollow65 | 01/03/2015 3:00 AM |
| 55shaker | 01/03/2015 3:02 AM |
| 55shaker | 01/03/2015 3:15 AM |
| Hollow65 | 01/03/2015 3:23 AM |
| MikeE | 01/03/2015 3:54 PM |
| Hollow65 | 01/03/2015 7:43 PM |
| Steve_H | 01/03/2015 6:49 PM |
| KeeneBolter | 01/03/2015 10:24 PM |
| KeeneBolter | 01/04/2015 11:20 PM |
| don stocker | 01/04/2015 11:42 PM |
| Hollow65 | 01/04/2015 11:43 PM |
| VEW | 01/05/2015 9:32 PM |
| KeeneBolter | 01/05/2015 10:04 PM |
| tclederman | 01/05/2015 10:29 PM |
| don stocker | 01/05/2015 11:04 PM |
| TJ's Chevy | 01/05/2015 11:18 PM |
| Hotrod Lincoln | 01/05/2015 11:30 PM |
| wetwilly5757 | 01/06/2015 12:46 AM |
| KeeneBolter | 01/07/2015 1:36 AM |
| Volfandt | 01/07/2015 2:01 AM |
| Hotrod Lincoln | 01/07/2015 2:03 AM |
| KeeneBolter | 01/08/2015 3:32 PM |
| wetwilly5757 | 01/09/2015 1:26 AM |
| blanch53 | 01/13/2015 8:34 AM |
| KeeneBolter | 01/13/2015 8:30 PM | |
