| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 48 | Well, I think I found the problem! I dropped the oil pan tonight. No obvious signs of metal shavings or mechanical damage. The oil pan is full of sludge and very hard to see through. I shined a super bright flash light at the inside of the pan and saw a bright spot shining back. Long story short, the bottom of the oil pan was pressed in enough that it was rubbing on the crank shaft. Also there was no cork gasket just silicon so the pan was sitting a bit higher which didn't help. Here's the pics: http://i824.photobucket.com/albums/zz166/keenebolter/58%20Apache/image2_zpsb909bfd6.jpghttp://i824.photobucket.com/albums/zz166/keenebolter/58%20Apache/image1_zps70702e2e.jpgSo now that the pan is out I see that its full of sludge which I will obviously clean out but what else should I do while the pan is down? Is there an easy way to clean the black gunk off the inside of the engine? Should I take apart the oil pump and clean out the metal lines? I'd like to get as much sludge out of this thing as possible and clean it up a bit. Thanks everyone for the help and suggestions. That broomstick idea led me to the problem! | | | |
Entire Thread
235 engine noise, help needed!
| KeeneBolter | 01/02/2015 6:37 PM |
Re: 235 engine noise, help needed!
| VEW | 01/02/2015 6:57 PM |
| blanch53 | 01/02/2015 7:07 PM |
| KeeneBolter | 01/02/2015 7:10 PM |
| don stocker | 01/02/2015 7:34 PM |
| truckernix | 01/02/2015 9:03 PM |
| KeeneBolter | 01/03/2015 12:44 AM |
| MikeE | 01/03/2015 12:57 AM |
| Hollow65 | 01/03/2015 1:41 AM |
| Hollow65 | 01/03/2015 3:06 AM |
| don stocker | 01/03/2015 2:29 AM |
| Hotrod Lincoln | 01/03/2015 2:45 AM |
| KeeneBolter | 01/03/2015 2:52 AM |
| Hollow65 | 01/03/2015 2:57 AM |
| Hollow65 | 01/03/2015 3:00 AM |
| 55shaker | 01/03/2015 3:02 AM |
| 55shaker | 01/03/2015 3:15 AM |
| Hollow65 | 01/03/2015 3:23 AM |
| MikeE | 01/03/2015 3:54 PM |
| Hollow65 | 01/03/2015 7:43 PM |
| Steve_H | 01/03/2015 6:49 PM |
| KeeneBolter | 01/03/2015 10:24 PM |
| KeeneBolter | 01/04/2015 11:20 PM |
| don stocker | 01/04/2015 11:42 PM |
| Hollow65 | 01/04/2015 11:43 PM |
| VEW | 01/05/2015 9:32 PM |
| KeeneBolter | 01/05/2015 10:04 PM |
| tclederman | 01/05/2015 10:29 PM |
| don stocker | 01/05/2015 11:04 PM |
| TJ's Chevy | 01/05/2015 11:18 PM |
| Hotrod Lincoln | 01/05/2015 11:30 PM |
| wetwilly5757 | 01/06/2015 12:46 AM |
| KeeneBolter | 01/07/2015 1:36 AM |
| Volfandt | 01/07/2015 2:01 AM |
| Hotrod Lincoln | 01/07/2015 2:03 AM |
| KeeneBolter | 01/08/2015 3:32 PM |
| wetwilly5757 | 01/09/2015 1:26 AM |
| blanch53 | 01/13/2015 8:34 AM |
| KeeneBolter | 01/13/2015 8:30 PM | |
