1 members (Ole49GMC),
109
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I can't really see a problem with going with an 8 lug hub.
One issue I see is with the brakes. I would go with a 52 and newer, in order to get Bendix style brakes. Of course the 3800 trucks will have the larger brake drums.
Wheels, not for sure what to tell you. Are you going with SRW or Dually? Wanting to update to newer Steelies or Aluminum? If you go SRW, the most backspacing you can have is 4.25" don't know about duallies.
One of the advantages of going to 8 lug, is being able to swap in a later 14 bolt axle for better gearing.
Anyhow, I'm all for it.
Entire Thread
spindles, wheels, and tires
| tko | 12/07/2014 3:10 AM |
Re: spindles, wheels, and tires
| Grigg | 12/07/2014 2:29 PM |
| Dodgecummins | 12/15/2014 11:10 PM |
| Grigg | 12/15/2014 11:57 PM |
| Whitedog | 12/16/2014 2:06 AM |
| Grigg | 12/16/2014 2:18 PM |
| Dodgecummins | 12/18/2014 5:06 AM |
| Grigg | 12/18/2014 5:27 PM |
| Whitedog | 12/18/2014 5:30 AM |
| Dodgecummins | 12/19/2014 4:24 AM |
| Whitedog | 12/22/2014 4:59 AM |
| Grigg | 12/19/2014 4:42 AM |
| Dodgecummins | 12/19/2014 5:00 AM |
| tko | 12/21/2014 3:12 PM |
| Rich'sToys | 12/22/2014 5:23 AM |
| Grigg | 12/22/2014 11:02 PM |
| tko | 12/25/2014 4:44 AM | |
