| | | Forums66 Topics128,022 Posts1,055,360 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2014 Posts: 63 | The heater in my 1948 Chevy 3100 truck isn't working. I traced the hot wire from the blower motor and found the other end loose. It was soldered so I knew it broke loose from its connector. Well I found the connector. It has a fusible link connected to the ignition switch. I disconnected it from the ignition switch and it has a 14A fuse in it. My truck has been converted to 12V yet isn't a 14A fuse typical with a 6V system? What do I do? I have looked at the different part suppliers and cannot find the fusible link that plugs into the ignition switch. | | |
