| | | Forums66 Topics128,114 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | http://speedprint.com/deves50/flywheel.phpNot alot of other flywheels that would even fit. Probably the problem is you have the wrong starter for the flywheel. I for one like to change the starter rather than the flywheel. Im lazy that way. If you have a 235 with a flywheel, chances are its one of those two. I am no expert. Ask Pre68Dave or HotRodLincoln, but I am not aware of any other flywheels available for the 235 of ANY year. Where they come in, is I am not sure the 250, or whatever newer engine flywheels would fit. If they do, then all bets are off. In any case, its good advice to get the other starter like Steve, Roy, Brad, everyone else says. | | | |
Entire Thread
Flywheel, from hell.... and starter issue 47 1 ton, ~1960 engine
| Knedert | 11/11/2014 6:04 AM |
Re: Flywheel, from hell.... and starter issue 47 1 ton, ~1960 engine
| steve sr | 11/11/2014 6:32 AM |
| Knedert | 11/11/2014 7:44 AM |
| Uncle Brad | 11/11/2014 6:55 AM |
| Steve_H | 11/11/2014 7:41 AM |
| Knedert | 11/11/2014 7:50 AM |
| Knedert | 11/11/2014 7:56 AM |
| Knedert | 11/11/2014 7:53 AM |
| Knedert | 11/12/2014 12:07 AM |
| Uncle Brad | 11/12/2014 12:21 AM |
| Roy Rodgers | 11/12/2014 2:38 PM |
| Steve_H | 11/14/2014 3:17 AM |
| Deve | 11/15/2014 2:23 AM |
| delux54panel | 11/15/2014 4:25 AM |
| Steve_H | 11/15/2014 10:05 AM |
| Pre '68 Dave | 11/15/2014 5:50 PM | |
