| | | Forums66 Topics128,114 Posts1,056,613 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 74 | Yes, I have a 12 v flywheel. Also, the engine doesn't have any tight spots at all. Compression is an even 110-120. Every connection is beyond tight and bright, less that 1/2 a volt drop on both positive and ground circuits - the cables are new, the battery is new.... I was really [censored] that I wasn't able to troubleshoot this. Well, until this little gremlin.
So, is there a different tooth angle or geometry within the 168 tooth, 12V flywheels? Or, if I get a 168 tooth wheel am I all good? | | | |
Entire Thread
Flywheel, from hell.... and starter issue 47 1 ton, ~1960 engine
| Knedert | 11/11/2014 6:04 AM |
Re: Flywheel, from hell.... and starter issue 47 1 ton, ~1960 engine
| steve sr | 11/11/2014 6:32 AM |
| Knedert | 11/11/2014 7:44 AM |
| Uncle Brad | 11/11/2014 6:55 AM |
| Steve_H | 11/11/2014 7:41 AM |
| Knedert | 11/11/2014 7:50 AM |
| Knedert | 11/11/2014 7:56 AM |
| Knedert | 11/11/2014 7:53 AM |
| Knedert | 11/12/2014 12:07 AM |
| Uncle Brad | 11/12/2014 12:21 AM |
| Roy Rodgers | 11/12/2014 2:38 PM |
| Steve_H | 11/14/2014 3:17 AM |
| Deve | 11/15/2014 2:23 AM |
| delux54panel | 11/15/2014 4:25 AM |
| Steve_H | 11/15/2014 10:05 AM |
| Pre '68 Dave | 11/15/2014 5:50 PM | |
