| | | Forums66 Topics128,113 Posts1,056,612 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | The flywheel comes in 2 versions. A 6 volt and a 12 volt. Yep, the trick is to match the flywheel and the starter. A 6 volt starter will work just fine on a 12 volt truck. Turn that ring around on the flywheel and match the correct starter to it. And you will drive away happy. There is a different tooth count and pitch to the ring. The tooth count is easy to find in "search" but here it is.Tooth count, 6 V is 139 teeth and 12 volt is 168 teeth. The starter has the same number of teeth for 6 and 12 Volt, but the pitch is very different. There is a difference in the shaft diameter. A good rebuilder will know what you have.
Steve H
Entire Thread
Flywheel, from hell.... and starter issue 47 1 ton, ~1960 engine
| Knedert | 11/11/2014 6:04 AM |
Re: Flywheel, from hell.... and starter issue 47 1 ton, ~1960 engine
| steve sr | 11/11/2014 6:32 AM |
| Knedert | 11/11/2014 7:44 AM |
| Uncle Brad | 11/11/2014 6:55 AM |
| Steve_H | 11/11/2014 7:41 AM |
| Knedert | 11/11/2014 7:50 AM |
| Knedert | 11/11/2014 7:56 AM |
| Knedert | 11/11/2014 7:53 AM |
| Knedert | 11/12/2014 12:07 AM |
| Uncle Brad | 11/12/2014 12:21 AM |
| Roy Rodgers | 11/12/2014 2:38 PM |
| Steve_H | 11/14/2014 3:17 AM |
| Deve | 11/15/2014 2:23 AM |
| delux54panel | 11/15/2014 4:25 AM |
| Steve_H | 11/15/2014 10:05 AM |
| Pre '68 Dave | 11/15/2014 5:50 PM | |
