1 members (1 invisible),
116
6
Mod | | | Forums66 Topics128,261 Posts1,058,342 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,944 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,944 | It would probably be better to acquire a tighter-fitting sleeve if possible. Every time you shift, or change throttle position the spline will work itself back and forth and wear the sleeve a little more. Eventually you'll get a click noise from the slack. Jerry
