1 members (1 invisible), 111 guests, and 5 robots.
Topics128,261
Posts1,058,342
Members48,485
Here's one for guys who have experience with replacing a pinion or the Patricks 3.55 conversion:
How much play is acceptable between the pinion splined shaft and the driveshaft?
The manual shows using a big old puller for removing and replacing the pinion shaft. So must the splines themselves always be a tight fit? Or will the pin hold the whole setup together?
Mine had a broken pin, and the splines are a loose fit.
52 3100 project
54 3100 / 3112 ice cream truck, next project
H Online: Content
It would probably be better to acquire a tighter-fitting sleeve if possible. Every time you shift, or change throttle position the spline will work itself back and forth and wear the sleeve a little more. Eventually you'll get a click noise from the slack.
Thanks, yes, that's what I was worried about. The various instructions dont mention how snug the spline fit itself has to be vs. how much tightness/stress is taken by the pin.
Has anyone pinned a loose fitting spline to get it tight enough?
52 3100 project
