By the time I get around to it Tim you will probably be ready
for a new set of tires. Ain't gonna be any molds made till I
get the mills up and running and they ain't gonna be running
till I get the electric run to the other end of the building
and that ain't gonna be possible till I get the insulation
and sheeting on the inside wall and that probably ain't gonna
get done till I get the flue thru the roof so I can get some
heat out to the shop. Soooooo....you see, lots of wishful
thinkin' goin' on around here.
dg
Denny G
Sandwich, IL
