Hi all,
Finished installing the SBC in my 56 3100 pickup. The new engine uses side mounts from Trans Adapt - easy installation but the driver's side motor mount interferes with the emergency brake arm. I am sure other folks have already solved this problem. Any clever solutions out there that retain the original brake lever in the cab?
Thanks!
