3 members (Otto Skorzeny, DennisM, 1 invisible),
140
Mod | | | Forums66 Topics128,281 Posts1,058,461 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | Just finished working out the bugs in a rewiring. Here is a minor question. The ignition switch has three posts, one for positive in to the switch, one out to engine ignition, another out to accessories. But both the accessory post and the ignition post are activated simultaneously when one turns the key. The keyed switch only has two positions, on and off. Why the two posts, is it just to avoid having too many wires running from a single post? Why shouldn't I wire other accessories (turn signals) from the ignition post if I want to avoid having too many wires running from the other post? Karl It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | |
