| | | Forums66 Topics128,162 Posts1,056,945 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | There may be a plug at the bottom that a 1/2" square drive ratchet will fit in. The hole for the ratchet is usually plugged with dirt. If not, thee is nothing wrong with removing lower bolts. I would let it drain for a day or so. The stuff is probably pretty stiff and will smell like a skunk. | | |
