DADS50, It ran before I started my restore. The distributor is new, I just replaced it thinkin' it was my problem. I got the cap and rotor at the same time, same supplier. When the pointer is on the ball, the rotor is pointing at 1...about 1 o'clock.
Jim I'm going to start from scratch and test everything again. Maybe some of the stuff I put on is not good and I'm not seeing it.
Thanks everyone, I'll get back to you
Steve
