I've got an 8v battery in my 53. After tweaking the regulator it has been doing just fine, no unusual problems with the bulbs either. That said, if you need a new battery do as Cletis says, go back to 6 v. My guess is that your guy (and my Napa guy) had 8v batteries in stock but no 6v. Those 8v things work well on the farm, so why not in a truck? That is the line I heard...
I would wonder if the trickle charger is too fickle, I charge my 8v with a standard 6v charger.
Karl
