8 members (ShopRag, TUTS 59, 1955 1 Series, Deegs53, dt235sd, treegrower, Otto Skorzeny, 1 invisible), 71 guests, and 2 robots.
Topics128,265
Posts1,058,138
Members48,482
Previous Gallery
Next Gallery
4 Images
1937 Chevrolet 1/2-ton Pickup
I purchased this truck from a fellow Stovebolter who had started restoring it and the project stalled. One of my sons, Lightholder on this forum, went on a road trip with me to retrieve this from the West coast.
The truck was disassembled down to a bare frame and then reassembled. I spent four years doing much of the work myself, although most of the body work and painting was done by a local shop.
My goal was to have a truck that is as close to stock as practical.
It has the original design drivetrain including a 4 speed non-synchronized transmission and 216 engine.
The electrical system is 6 volt with the original voltage cutout (no voltage regulator). I did take some liberties with modern products such as Remflex manifold gasket and Cunifer copper nickel brake and fuel lines.
The tires are Coker radials in the original size 6.00x16.
The original bed was kind of beat up, as the truck had been a landscaping truck for part of its life. I purchased a new bed and bed wood from Mar-K. As you can see from one of the photos , I painted the bed wood black so that it would appear stock, using the process described on Mar-K’s website.
Much of the restoration process would be familiar to you all but one aspect. I would like to highlight is how much work went into the fuel system to return it to the original configuration. The 1937 trucks are unique in that this is the only year there is no fuel filler tube for the under seat gas tank.
The bench seat is split, allowing you to raise the passenger half of the seat to reveal the gas tank cap or bung. It is not vented; the tank itself has a vent that exits at the bottom of the tank, just above a hole in the cab floor. To fill the tank, you open the passenger door, lift up the seat bottom half, open the bung and fill-er-up.
Well, unfortunately when I got the truck, it had a car gas tank strapped under the bed with the fill tube protruding through an ugly ragged hole in the passenger fender. The seat base that surrounds the stock gas tank had been removed and someone had constructed a wood seat that sat on the cab floor.
To return the truck to stock configuration, I ended up buying a bare late 1936 cab, cut the 35 spot welds holding down the seat base and welded it to the 1937 cab. Another Stovebolter sold me a nice original gas tank and seat back. I located seat bottoms from a local junk yard here in the desert.
The truck is a blast to drive and I have really fallen in love with the look of that era truck.
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
14 Comments
Former Workshop Owner
What a great truck and story. I'm glad that you explained the effort you took returning the gas tank to it's original configuration. I wasn't aware that they came from the factory like that.
Thank you for sharing your story and pics.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Looks nice. The green looks great.
1949 5 Window 3100
Follow in the DITY
Veteran of the USAF
My Website
Looks great!
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
what my GC strives to be when she grows up! Still molting farmers parts and modifications.
Larry
Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY.
If you are missing one component, you'll need an abundance of the others two.
Beautiful! I have a 37 and am considering modifying the stock tank to add a filler tube. I don't know how I'll do it.
You’d think the ‘38 parts could be used for a direct fit butI don’t know. I’m planning on keeping mine original
Larry
The 38 tank would work in a 37 but the 38 tank is are very rare and not reproduced.
That is a truck to be proud of. You did a wonderful job !
Jim
1950 Chevy 3100
In the DITY Gallery
77 International Scout ll
96 F-150 ext cab 4x4
2000 Tahoe
2011 chevy 3/4 ton 4x4
? Offline
Hello, I’m new the this site and I also own a ‘37 half ton. If I may, I would like to ask if there is anyway you could take careful photos of the seat bottoms and more specifically how they properly mount to the riser. My truck came with the original seat back with the original mounts. Both seat bottoms are long gone so I found a set on EBay but once again, no mounts. If you should happen to know of a set of mounts or a set of seat bottoms I would be very interested in speaking with you. Thank you in advance, Dan.
I am away from my shop where the truck resides for several days so I will be glad to send you some photos after this weekend. The seat bottoms rest on the riser directly and there are some v-shaped metal extensions that restrict front to back movement of the seat bottom relative to the riser. That is all. Pictures to follow.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Apparently, one cannot post pictures in a reply in this section, so '37ChevyPU, if you want to see pictures send me an email. My address is in my profile.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1951 Chevy 1/2 ton
Kent, you are correct. Gallery guidelines state Do Not Ask Questions in the Gallery, so the need for photos in reply is locked out.
Just received my copy of "Hemmings Classic Car" magazine in the mail today. It features a very nice article about this truck.
You obviously put a lot of effort into it. Very nice job, and congrats on the article!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Authorized Pest
Authorized Pest
Kent's truck just came up again in the discussion in General Truck as the link to the Hemmings Motor News story featured his '37.
Just wanted to add it here for this thread.
wave
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
