2 members (Sjm, baldeagle),
178
Mod | | | Forums66 Topics128,254 Posts1,057,979 Members48,478 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 74 | Hi guys, ive got my truck stripped down and almost ready to lift the body off.
still got to remove the doors, am going to leave front glass in?
chassis ive still got engine in, but all removable metal work has gone...from fenders both front and rear,bonnet ect.
im really worried about lifting the body off, ive got the use of a fork truck..so was going to put that in the opening of the back doors (and lift with protection and wood across the folks)..
then through the front door opening..span a large piece of wood and jack it up pushing against the top of the door openings??
any thoughts on this!. ive the week of work to tackle it...!
1953..panel truck.I love my truck!...
| | | | | Joined: May 2007 Posts: 321 Shop Shark | | Shop Shark Joined: May 2007 Posts: 321 | I used a two post car lift at a friends shop. Easy as pie. Rolled out the chassis and rolled under my car dolly. | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I used a two post car lift at a friends shop. Easy as pie. Rolled out the chassis and rolled under my car dolly. Patrick, I was just looking for this information in your album, but your album does not work. Dano&rose, I know if you do a search you can find this topic including pictures of what others have cone. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Red58 has covered panel truck body removal with fork lift on this forum. Search for it, it is very helpful.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | It's not that difficult. Do you have a 4 speed? You need to twist off the gear shifter. Fork lift through the back works well. | | | | | Joined: Oct 2005 Posts: 4,262 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,262 | See my link below to see how I did my Burb! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes easy, put some narrow pallets on the forks to take up the curve to the roof ribs, rope from the mast thru the front doors to keep it from tipping forward, Bob's yer uncle  Bill | | | | | Joined: Mar 2010 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 74 | thankyou very much chaps...will try post some photos to show you what im up to for the winter!
| | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | we supported the underside lifted at the bodymounts with a floor Jack (2)4x6" and few sparetires. | | | | | Joined: Mar 2010 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 74 | thanks Dogs, will have a look in the morning about trying this. how did you start the lift (to get the wood in?) and did you do the same on the rear end?
| | | | | Joined: Nov 2001 Posts: 438 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 438 | Dano & Rose, I did similiar method as Dogs but use a "cherry picker" used to remove motors as you can get couple feet of lift. If you jack up body couple of inches form underneath then you can use chain or straps bolted to the body mounts. Just go slow and think safety first. Good luck
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
| | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | we used lots of little blocks and some jackstands welded a metal 4x4 to extend jacks reachback endfront end upalso Look at my progress Pics link: PS. anyone doing a frame change, we made a plywood drill template that worked. Frame to frame the body mounting bolts dropped right in.
| | | | | Joined: Nov 2012 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 51 | Hi; Here is what I did in a small garage. I had no rotisserie so I built a floor to ceiling 2x4 frame work as a box. I bought 4 jack alls to place in each corner bolted top and bottom to a vertical stud. I then used to 4x4 fence posts to span across front and back. I used hydraulic jacks to get the body started upwards and then shoved in the posts. I can now jack one at a time by the click up or down until the chassis and underbody are ready to jack downwards for the finale. Costs were about $250. for the jacks and $50. for lumber and bolts. Cheers | | | | | Joined: Mar 2010 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 74 |
| | | | | Joined: Nov 2012 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 77 | | | |
