| | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 50 | Hey I was gonna order new weather stripping for vent windows from LMC,I noticed one side just pushes in.But the other side has rivets. anybody replace these how does it work. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Its as you say. One side is rivited and can be a pain. A lot of guys glue those on and some are sucessful with the rivets. I used some adhesive on mine and so far so good..... it is an AD style isn't it? | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | I musta lucked out on mine. I replaced them in my '54 last month. The rivets in the rigid rubber seal and the pivot rivet went in without much problem. Suggest you buy extra rivets for the seal and for the pivot. You may not need them, but it gives peace of mind. I used a piece of 3/8" plate in my vice to back up the rivets. The plate fits inside the vertical window track. Set them with the little rivet tool from the parts supplier and a hammer. I thought that I could replace the seals without removing my vent glass/frames. Wrong. You must remove them in order to replace the rubber seal around the vents. And it makes setting the rivets easier, too. Here are some recent theads that may help: Thread #1Thread #2Thread #3
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 50 | | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I clamp a 1964-1966 truck door hinge in the vise and use the edge to set the rivets.One of these days I will take step by step pictures of the process.Sometimes a extra set of hands make the job easier.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
