8 members (SammyC60, TUTS 59, 52Carl, Mike Roache, TooMany2count, Hawkman, Otto Skorzeny, 1 invisible),
101
Mod | | | Forums66 Topics128,101 Posts1,056,518 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 54 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 54 | My 3800 project came with some worn out 7.00-17 tires. I couldn't find replacements that were correct, i found some that were not a truck type tire made for older cars, so I bought some 7.50-17. I just aquired some NOS 7.00-17 BFG's. They are perfect and unmounted. Are these hard to find? Should I use them on a truck I plan to drive a lot, or save them for more of a show truck? Thanks, Josh | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Coker Tire sells new tires that size, I'm sure there are others. I'd stick 'em on, and wear 'em down! | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | Tornel makes a decent bias tire. Made in Mexico. I have used them for years and just had some recapped. They look good and work fine. I believe they cost about $150 apiece around here.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Cooper makes 7.50x17 "Hiway" and "Mud/Snow" tread tires. They are 8 ply bias tires. I got them on my '48 3800. Very happy with them. Put almost 40K miles on them now. The truck is a daily driver. I've had poor experience with Coker Tire and would NOT recommend them to anyone. | | | | | Joined: Dec 2004 Posts: 20 New Guy | | New Guy Joined: Dec 2004 Posts: 20 | Josh, I run 17's all the time although I keep the air pressure lower than the maximum pressure on the sidewall. Check it out http://www.stovebolt.com/gallery/evans_jeff_1951.htmlJeff PS Nice handle... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | How old are the tires? In the tire market for new replacement, anything over 4 years old generaly isn't sold, due to liabilties over tire age. Unless you know how the tires were stored, and the age of the tires (6 years or less), I would not suggest using them as daily use tires.
Bill Burmeister | | |
