5 members (Jon G, frogfarmer, Cletus1950, Wally / Montana, greenie-reddy), 152 guests, and 6 robots.
Topics128,106
Posts1,056,213
Members48,436
#785583 10/03/2011 12:18 AM
My 3800 project came with some worn out 7.00-17 tires. I couldn't find replacements that were correct, i found some that were not a truck type tire made for older cars, so I bought some 7.50-17. I just aquired some NOS 7.00-17 BFG's. They are perfect and unmounted. Are these hard to find? Should I use them on a truck I plan to drive a lot, or save them for more of a show truck? Thanks,
Josh
Pa Farmer #785718 10/03/2011 4:43 PM
Coker Tire sells new tires that size, I'm sure there are others. I'd stick 'em on, and wear 'em down!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #785744 10/03/2011 5:50 PM
Tornel makes a decent bias tire. Made in Mexico. I have used them for years and just had some recapped. They look good and work fine. I believe they cost about $150 apiece around here.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
MikeE #786903 10/07/2011 1:24 PM
Cooper makes 7.50x17 "Hiway" and "Mud/Snow" tread tires. They are 8 ply bias tires. I got them on my '48 3800. Very happy with them. Put almost 40K miles on them now. The truck is a daily driver. I've had poor experience with Coker Tire and would NOT recommend them to anyone.
Pa Farmer #787473 10/10/2011 2:47 AM
Josh,
I run 17's all the time although I keep the air pressure lower than the maximum pressure on the sidewall.
Check it out
http://www.stovebolt.com/gallery/evans_jeff_1951.html
Jeff
PS Nice handle...
PaFarmer #788072 10/12/2011 3:36 AM
How old are the tires? In the tire market for new replacement, anything over 4 years old generaly isn't sold, due to liabilties over tire age. Unless you know how the tires were stored, and the age of the tires (6 years or less), I would not suggest using them as daily use tires.
Bill Burmeister
Moderated by  Dusty53
