Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (TUTS 59, baldeagle, dunfire, Rnl364, stlcardinalsguy), 41 guests, and 2 robots.
Topics128,004
Posts1,055,246
Members48,418
my '52 needs some interior paint. the original 'sun beige' is poking through in places and i'd like to repaint a similar color, but on the cheap w/ rattle cans. anyone had luck finding a close match off the shelf?
Here is the rattle can I used on my 50. It matched pretty good the original color that was on there but Im not sure if its "sun biege"
...pic...
steering wheel, colum, and shifter
...pic...
flash pic
...pic...
may not be "sun biege" but could be a option
Yeah, that all looks great - the hammered bronze paint in particular came out super nice...
thanks
I didnt see a 51 in your signature
do you have any pics?
'52. typo. corrected above.
Yep, that Rustoleum is a fairly good match for the original paint.
The absolute best match I've seen so far and several of the guys here have used it, is the offset formula from the PPG color library for the original Ditzler formula. That would be PPG DBU 27467 shown here along side the Rustoleum 7272: http://www.pbase.com/dennygraham/image/123581933/large
http://www.pbase.com/dennygraham/image/123581336/large
The Rustoleum is about ten times cheaper than the PPG DBU so if your not doing a show truck it's a good look alike.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Great, Denny and DADS50 - thanks to you both.
Big Bolt Forum Co-moderator
I have a 1948 that I am fixing up, not show truck, but fun truck, and want it to be close to the correct color. Would the rustoleum 7754 and 7272 be close for my truck?
1948 Chevy 2-Ton
I was able to find a spot on the firewall of my 50 that still had the original color ...pic...
The 7272 was very close to that color. Not an exact match but close.
The 7754 I found at the hardware store and used on column, shifter, and steering wheel for contrast. This color may not be close to original.
Here is a pic using camera flash you can see the difference. ...pic...
Will it match a 48? Dont know, Someone else will have to answer that.
Ive seen some AD cab interiors that were silver, or gray. If thats the case These rattle can colors are not close at all.
Next time I'll go with the color code Denny posted earlier and spray it.
For a rattle can budget job I was pleased with the results I went from this to this
Good Luck
