8 members (mk72, Gdads51, ShopRag, TUTS 59, Hush, Otto Skorzeny, Hugh63c10, Hanks custodian),
149
Mod | | | Forums66 Topics128,043 Posts1,055,524 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 49 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 49 | old thread-revival. chevs of 40's has them and also chevy duty(classic parts america)
has anyone bought one and used it? how did it fit? who made it? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | For what style heater?
For what year heater?
| | | | | Joined: Jan 2006 Posts: 49 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 49 | sorry-the 47-55e fresh air or airflow heater that has the rectangular type core. | | | | | Joined: Jan 2011 Posts: 2 New Guy | | New Guy Joined: Jan 2011 Posts: 2 | The Brassworks in Paso Robles, CA makes and restores heater cores.
www.thebrassworks.net | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | sorry-the 47-55e fresh air or airflow heater that has the rectangular type core. There are still two different styles for that year range. Up to 53 has a core that is currently reproduced and sold through many vendors and the 53-55 1st has a side "flap door" on the front and takes a slightly different core. | | | | | Joined: Jan 2006 Posts: 49 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 49 | There are still two different styles for that year range. Up to 53 has a core that is currently reproduced and sold through many vendors and the 53-55 1st has a side "flap door" on the front and takes a slightly different core. do you know the difference? is is mounting straps or core dimension differences? I have about 10? of the flap versions and maybe 8 of the normal kind. most are blown apart though... wasnt aware off differences when I took them apart and assumed chevy was too cheap to have 2 different cores. will carefully take apart both OEM kinds to see if I can figure it out if I dont hear from you-thanks mark | | | | | Joined: Jan 2006 Posts: 49 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 49 | i followed link. um-they are REALLY REALLY proud of their work. $670 for a radiator means heater core gonna be?? 200?? | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | copanel, let us know what you find out of the difference between the 2 rectangular cores in mounting ect.... I figure the core looks the same only the tubes coming out of them might be different.
John | | | | | Joined: Jan 2006 Posts: 49 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 49 | tube output location are identical for sure. all cases are same on back side. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I have a fresh air heater with ranco valve and rebuilt core for sale... $75 plus shipping. HERE I listed this some time ago in the FS section but now I can't find it. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Woody, good to see you check in!! swap meet ads do expire over time, and the recent upgrade of the forum software may have affected things as well, renew any offers you had
Bill | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | tube output location are identical for sure. all cases are same on back side. I know new heater cores only list up thru 1952 fresh air. Something must be different? Like you I can't think GM redesign to much when they added the door for recirculating to the heaters in 1953-55 1st... John | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Originally Posted By: ccpanel
tube output location are identical for sure. all cases are same on back side. Not quite correct. The new style heater has the tubes slightly staggered and the old style has them pretty much in line with each other. The tanks on the old style are taller and the mounting provisions different. I assume to make room for the "front trap door" Old style core This is best I could find for new style off hand I had pictures of both cores side by side but cannot find them right now. | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Jim Carter sales both heater cores 1953-55 and 48-52
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Cool! When the cores are side by side, it is easy to spot the difference. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Good to see Jim carter has the newer one if needed. Chevy Duty only listed the earlier one... John | | | | | Joined: Jan 2006 Posts: 49 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 49 | both jim carters are NOT for the recirc fresh air heater according to description. pics on the jim carter site are of the exact same core.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I thought they looked the same also, but thought maybe I wasn't seeing something everyone else could....LOL
John | | |
