| | | Forums66 Topics128,049 Posts1,055,747 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Anybody here ever try this product to stop a leak like the dripping from the rear main on my '56 235. Seems too simple and probably is just the lazy way of (maybe) treating a leak that otherwise takes time, work, and the appropriate know-how to accomplish a main bearing seal replacement. Haven't bought it yet, just checking on ways to end those pesky leaks.  Thanks, Dale | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I gave that stuff to my spare engine last week.... did it fix your drip?
| | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Hi CASO - I haven't tried it yet - just wondering if anybody had any experience with it before I give it a try.I'm always leery of additives. Seems there is always some side effect (sort of like prescriptions) you might not anticipate. Just don't want to wish later I didn't just go ahead and do the harder but more permanent work of replacing the seals. There is a tech tip here that Oly provided that explains how to do the replacement, but it doesn't sound real easy. This is just one last look before I jump in and learn my way through that better solution. Dale | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Dale, I was just messing with you... Wondering if that stuff in MY engine fixed YOUR leak... Honestly... I didn't even click on the link.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think additives for stopping leaks only work on neoprene seals. There are some good ones for automatic transmissions but rope rear main seals, not so much. | | |
