9 members (Phak1, Bill Hanlon, Rusty Rod, TUTS 59, Napco Man, Cosmo, ndkid275, 2 invisible),
57
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99957 03/18/2007 8:44 PM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | i just upgraded to 12 volt - alt. & coil new battery . used a da plug from randy . i was expecting some movement on the amp gauge , but i see no detectable movement . it's a master 85 , 1939 model . would 6 volt calibration be the cause ? thanks , frank | | |
#99958 03/18/2007 9:00 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Frank,
Did you wire the alternator output..BATT, through the old harness, or in such a way that it affects the ammeter. The meter will read whatever passes through it, no calibration required.
Stuart | | |
#99959 03/18/2007 9:28 PM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | yes stuart , i blew the big bucks on a new ynz wire harness . i wanted to keep the voltage regulator for looks ( i gutted it ) . i hooked the alt. to the original ( new ) wire from the generator ( now alt. ) to voltage box. there i piggy backed ( joined ) the wire that goes into the amp gauge that connects to the ign. switch ( v.i.a. ) wire that goes to batt. terminal that is on foot starter . maybe w / new battery etc. , the alt does not have to put out any juice yet ? i don't have any lights etc. so i can't do a draw down yet . she really spins w/ the 12 v! thanks for your help . frank | | |
#99960 03/18/2007 10:54 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Frank, Sounds interesting. Maybe you're right about the new battery not needing any 'juice' yet. Without any lights or items online to pull from the battery, you won't see any discharge. It would seem to me even with a brand new battery that the ammeter should pop to + if only for a second or two. As things progress in the wiring, all will be revealed. Stuart | | |
#99961 03/19/2007 12:33 AM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | | | |
#99962 03/19/2007 12:50 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The ammeter should be your only connection between the battery post on the starter and the load, including the ignition switch and the alternator. In other words, only one wire goes from the battery terminal on the starter to one terminal on the ammeter and the other terminal on the ammeter goes to the load. Your ammeter should show a slight discharge when you turn on the ignition, unless the points are open, and go into the charge area when the engine starts. | | |
#99963 03/19/2007 1:44 AM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | thanks baldy - i will double check everything . frank | | |
#99964 03/20/2007 11:51 AM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | my son put battery tester on & it showed no charging . taking it back to have napa check it .thanks for all the input .  | | |
#99965 03/20/2007 3:12 PM | Joined: Feb 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 83 | update - a bad alternator - no output ! | | |
