| | | Forums66 Topics128,013 Posts1,055,322 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 122 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 122 | Hello everyone, Im at the near end of restoring my 50 Chevy 1ton and last night I was installing the key lock to the passenger door, and couldnt even budge the locking mechanisim on the latch without twisting the key off. Its a brand new latch too, Ill take it apart tonight and look at it. Has anyone else had a similar problem or a quick fix for this? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Are you using the original latch? They can get very dirty and weather beaten due to their location. I would suggest cleaning the latch mechanism if you have not done so. I would guess the lock mechanism was rarely used on many of these trucks. | | | | | Joined: Nov 2010 Posts: 122 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 122 | Its a new latch from Classic parts, it feels more like it needs to be "worn" in | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I am having the exact same problem with a new latch I bought for my '51 from JC. I gave up and reworked the old latch and installed and it works fine now. | | | | | Joined: Nov 2010 Posts: 122 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 122 | I was having the same issue with the brand new drivers side as well. Well when I thought I fixed it, it ended up busting apart | | |
