7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost), 126 guests, and 1 robot.
Topics128,056
Posts1,055,799
#977455 10/09/2013 3:24 AM
I can only get about 40mph and the engine sounds like it wants to come out from under the hood need to know what I can do and keep the 10 lug rims
r's 4100 #977476 10/09/2013 4:20 AM
Some more details Please
20 x 7.50? 4 speed? 2 speed rear?
Does sound like 2 speed axle in low range.
Attach a hand held tachometer and see what the rpm really is.
r's 4100 #977687 10/10/2013 4:06 AM
OK it has single speed rear axle and 7.5 20 tires. It has a 58 235 with 4 speed trans
r's 4100 #977745 10/10/2013 2:26 PM
There were 2 rear end ratios available, about 6.2 and 5.4.
With 7.50 bias ply at 60mph you would be doing about 3550 rpm or 3050 rpm respectively.
r's 4100 #999340 01/15/2014 12:11 AM
Empty with my 1949 4400, I can only get 35-40 mph. It too has single speed rear end, and the 7.50 x 20" tires. Not sure on the rear end ratio, but I do know the 235 came out of a late 50's sedan. Just how do you get 60mph out of the old stock truck? 60mph in this old girl would be fun, but might be a handful.
1949 1.5 Ton 4400, 1969 c10, 1989 c1500, 1990 K2500, 2010 C1500 Crew
r's 4100 #999369 01/15/2014 2:36 AM
I had 8.25 20's, on the '49 4400 I had, & could get 50 mph out of it. Also had a single speed rear axle.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
r's 4100 #999424 01/15/2014 1:10 PM
You could change to 8.25 or 9.00 tires on rear. Also keep in mind these trucks do not have the sound proofing a more modern vehicles have so more noise makes it to your ears. Truck speed limits at the time in many states often were only 45, I'm quite sure many drivers exceeded that.
r's 4100 #999493 01/15/2014 7:01 PM
I have 9:00X20:00's,on my 6500.(2-speed rear). Top speed is 55.(Hi-side). I wouldn't push the engine past its "Happy Zone". I still have a 1/4" left in the pedal travel,so I could go faster,but I don't want to shell a GOOD 261,that's survived 58 years. You may use the same rims,since the diameter of the tires stay the same,just a taller sidewall/profile. This may get you up to 50 M.P.H.,depending on your rear-end ratio.
Mo' Tater
