0 members (),
67
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 16 New Guy | | New Guy Joined: Jan 2014 Posts: 16 | Hey guys, I knew my cab needed a little work when I bought the truck, but the more I look and research, the more concerned I am... The floor is rusted through in the valley where the floor meets the rocker panel on both sides, the right side is worse than the left. Also I am a little concerned with the cab mounts. My main goal is to get the cab to a point where it will pass a safety inspection, but I also want it to be done right. Here are the pics: Right Rear Cab Mount The previous owner added a plate underneath for strength Right side Floor/Rocker Right Side Floor Previous owner riveted in some sloppy patches Right Side Floor/Rocker Left Rear Cab Mount Left Rear Cab Mount Left Front Cab Mount Left Front Cab Front OK, so now here is my questions. Do you think the cab mounts and cab supports need to be replaced? I assume the cab would have to come off the frame to do that. If that is necessary, can I just lift it 8 in and replace what needs to be done? My garage space is limited. LMC sells something called "Outer Floor Ext" is this what I need to repair the floor? Thanks a lot for the help guys. I have a welder and am learning as I go. Body work is not my favourite, but I recognize it as a necessary evil.
| | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | Any chance of you finding another cab? From your pictures, this one is pretty bad. I have fixed worse, but I would have been way ahead in money for just the replacement panels and welding supplies if I had looked for another cab in better shape. In saying this, I am not including my time in the cost. Carl
| | | | | Joined: Jan 2014 Posts: 16 New Guy | | New Guy Joined: Jan 2014 Posts: 16 | Well good cabs are harder to find in Canada and from the outside it doesn't look all that bad. Also the center of the floor is all good too. Its just the outside bottom that needs the work. I don't have a big budget for this project but I am willing to put in the hours if it needs it.
I'm just wanting to get it safety inspected and on the road for the time being. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | A lot of work ahead of you for sure. I say new complete floor and rockers for sure. Add in a few mount reinforcement pieces and maybe you can then pass inspection. Lots of work for sure. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | The project I am working on now... most people would have tossed this cab because everyone would agree its too far gone. Nothing from the floor down was salvageable, toeboard was shot, inside and outside panels, you name it. I was so adamant because 5 window cabs are hard to find and at the time, they didn't make the 5 window upgrade parts. I mention this because you can do it!  | | | | | Joined: Jan 2014 Posts: 16 New Guy | | New Guy Joined: Jan 2014 Posts: 16 | Thanks Deve, I appreciate the vote of confidence!
The way I understand it, it is almost impossible to get one completely rust free anyway. If I take my time and cut out all the rust I think I will be farther ahead in the long run.
Now, to replace the cab supports I assume I will have to lift the body... How terrible is that going to be? Does anyone have any tips? | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I fabricated a gantry crane from 4x4's and a steel cross tube. In this photo, my son and I just finished using it to install the engine. I also used it to hoist the cab. I made a simple frame out of 2x4 that went through both cab door openings. I used ratchet straps over the hoist beam to lift the cab (one on each side). The chain loop in the middle of the crane beam is where I hooked the chain hoist for lifting the engine. The crane was plenty stable and strong. The braces are electrical conduit. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Probably be better to leave it on the frame wouldn't it? To help hold alignment and lessen chance of twisting when locating and welding in panels.
| | | | | Joined: Jan 2014 Posts: 16 New Guy | | New Guy Joined: Jan 2014 Posts: 16 | I mean to replace the cab mounts and cab supports underneath. Do I need to raise the cab? Also, I don't want to take off the fenders unless I absolutely have to. Has anybody else done this? | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Just looking at your pictures, I would say the cab mounts and floor areas around them need to be addressed. The left rear looks like there isn't much holding there. Not sure if you can do the work without removing the front fenders or not. if you need to replace the rockers then I'd say you would. I believe originally there was a lip that turned up where the floor and rockers meet??? I guess you might just patch the rockers and leave the front fenders on.... John
| | | | | Joined: Mar 2010 Posts: 10,274 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,274 | I would do the repairs on the truck frame. You will have to jack up one side at a time to repair/replace your cab mount metal.
