4 members (Hotrod Lincoln, KCMongo, Peggy M, eclector), 166 guests, and 2 robots.
Topics128,034
Posts1,055,533
Members48,425
#99916 03/26/2007 2:46 PM
How can I get a radio in my 53 3/4 ton with out getting money fron Trump? It's still a 6 volt sys. and I can't see changing that just for a radio, plus a recondition one will be crazy,we only get one good station here,altho it's a oldie station. Was thinking of putting a battery under the seat just for a radio. Any input??? Thanks Paul
PJP
#99917 03/26/2007 2:59 PM
Paul,
Don't forget there is a good radio clinic a little further down on the main page...lots of radio guru's with good answers to your question.
Stuart
#99918 03/26/2007 3:02 PM
Ex Hall Monitor
Ex Hall Monitor
Google "vintage radio restorations". A fellow by the name of Tony Cerason restores vintage radios and may have one to fit your truck. I didn't bookmark it but I found an outfit on line that will take your existing 6v AM radio and convert it to 6v sterio with CD player (two speakers max) but they wanted $800 to do it. Another avenue is to check Hemmings Motor News.
#99919 03/27/2007 8:37 PM
Riding in the Passing Lane
There are converters to operate 12 volt radio,s on 6 volts. Radio Shack used to have them. I was going to go that route at one time but found a 6 volt radio. They just handle a small amount of curent so you can,t use it for high powered unit or other things.
1972 Chevy c10 Cheyenne Super
#99920 03/27/2007 9:45 PM
Its called a voltage inverter. I think i have one around here........somewhere........
Marty
#99921 03/28/2007 3:00 AM
Are you talking original dash mounted radio for your particular truck or just any radio mounted in the dash?
#99922 03/28/2007 7:43 PM
Technically, an inverter converts DC to AC, not DC to DC.
#99923 03/29/2007 1:45 AM
I think the inverter would be used in lieu of the vibrator if the radio is so equipped. Slap me if I'm wrong. ohwell
My 1941 in the Stovebolt Gallery
My Photo Album
But I tried, didn't I? ... At least I did that. RP McMurphy
The past belongs to the future...but only the present can preserve it.
Besides the noble art of getting things done, there is a nobler art of leaving things undone.
#99924 03/29/2007 2:04 AM
6 volt dc to 12 volt dc converter . See the link,it will help you with your search.You could search ebay,they usually have a few advertised.
http://www.powerstream.com/dc6-12.htm
This one shows you how to build one .
http://www.aaroncake.net/circuits/6-12conv.asp
Do a google search on 6volt to 12 volt power converter.
1951 3100 Chevrolet
#99925 03/29/2007 2:27 AM
Down2Sea,
Slap, slap.
#99926 03/29/2007 3:40 AM
I wasnt talking technically,,,i was talking what it says on the "inverter". It turns 6v to 12v.
