7 members (dt235sd, 3B, frogfarmer, 1955 1 Series, Bruce 1954-4100, DennisM, 1 invisible), 88 guests, and 1 robot.
Topics128,074
Posts1,055,910
Members48,429
I recently acquired this card of bolts to allow fine tuning of Chevy 6 distributors has anyone ever seen or used a similar item?
http://www.flickr.com/photos/advance-design_parts_co/11919031116/
I have seen a number of distributors with this set-up.
Wouldn't mind having that card.
My Blog
So it's a cam bolt to pre-load vacuum advance?
Drew
Looks like an eccentric screw.... would allow you to change the timing of the vacuum advance. It probably has about 1/16thin total swing.. that would add or reduce the effect of the advance by shortening or lengthening the effective arm of the advance giving you more or less degrees timing.
ojh Offline
Interesting. That is something to ponder about isn't it.
A shop is where you wash your hands before you pee.
Brad, do you have a close-up picture of one of those removed from the card? I'm curious how it is designed.
Carl
Carl,
Here is a picture of it exploded off the card.
http://www.flickr.com/photos/advance-design_parts_co/12005541513/
