7 members (Otto Skorzeny, Tronman, Lightholder's Dad, LAROKE, Stovebolt48, tclederman, 1 invisible),
75
Mod | | | Forums66 Topics128,042 Posts1,055,511 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 117 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 117 | Hello
I am just about to install the engine in the frame, rather than experiment I was wondering if someone can tell me if you can put the engine back in with the tranny installed to it, or is it easier to do them separately, also do the splash pans that go at the bottom side of the engine to frame go in first or after the engine is in thanks very much
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Yes, you can put the engine back in with the tranny installed to it. But, I'd say yes to: "is it easier to do them separately". The 47-55 Shop Manuals say the same thing, but I like to remove/install the engine/transmission separately. Wait to hear from people who have first-hand experience with a 46-era engine/transmission assembly. They will also know about the splash pans. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | On my bare frame, no cab,I put my engine in the frame then put the transmission in. I don't know if it would have worked better with them together but it went well separate. I have an overhead crane in my shop and it really makes a difference on doing jobs so it might differ for you. I would do it again the same way, separate. Much easier lifting that way. You have a solid foundation for putting the clutch/pressure plate in and then also solid for putting the transmission in.
My splash pans are in real bad shape and most likely will not go back in. Two reasons, real bad shape and they would take extensive modification to fit with the 235 replacement for the 216 in my 41. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
