1 members (baldeagle),
70
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | i just mounted a hurst shifter on my a833 tranny. i used a 1/4in drill to align the three shift levers in neutral. i made sure the tranny was in neutral. i hooked up the linkage. the result is that i can get all fwd gears but no reverse. i tried all the quadrants. tried pushing down and all the quadrants.
help
thanks rolf
1963 c10 | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | I am far from a expert, But did have the same type of problem with my Muncie 4speed and a Summit shifter. I had no luck when I lined up the levers with the 1/4in tool they provided. What I did was to turn the adjusting sleeve on the reverse shift rod to make it longer, a turn at a time, till reverse would engage.(makes the rod longer and pushes the lever more) Good Luck! | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I have been fooling with Hurst shifters for 50 years. Aligning with a bit is a starting point with. Then you have to play with until you get it right. | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | guys, i started over and made sure that the drill stayed "plumb" while i adjusted the linkage rods. i found that there is very little room for error for everything to be in neutral. once i redid the adjustment making sure the drill would slide in and out after each rod was adjusted i got reverse.
also i found some info on an oldsmobile forum that explains how to remove the stick. it worked perfect
thanks for your input guys
rolf
1963 c10 | | |
