0 members (), 108 guests, and 2 robots.
Topics128,035
Posts1,055,560
#997972 01/09/2014 2:22 AM
i just mounted a hurst shifter on my a833 tranny.
i used a 1/4in drill to align the three shift levers in neutral.
i made sure the tranny was in neutral.
i hooked up the linkage.
the result is that i can get all fwd gears but no reverse.
i tried all the quadrants.
tried pushing down and all the quadrants.
help
thanks rolf
1963 c10
I am far from a expert, But did have the same type of problem with my Muncie 4speed and a Summit shifter. I had no luck when I lined up the levers with the 1/4in tool they provided. What I did was to turn the adjusting sleeve on the reverse shift rod to make it longer, a turn at a time, till reverse would engage.(makes the rod longer and pushes the lever more) Good Luck!
I have been fooling with Hurst shifters for 50 years. Aligning with a bit is a starting point with. Then you have to play with until you get it right.
rgie #998291 01/10/2014 12:49 PM
guys,
i started over and made sure that the drill stayed "plumb" while i adjusted the linkage rods.
i found that there is very little room for error for everything to be in neutral.
once i redid the adjustment making sure the drill would slide in and out after each rod was adjusted i got reverse.
also i found some info on an oldsmobile forum that explains how to remove the stick.
it worked perfect
thanks for your input guys
rolf
1963 c10
