0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
#997922 01/08/2014 11:39 PM
Any pro. using a steel brake line for a gas line ....seams the same to me ...
" STUCK IN THE '50'S "
No problems at all, it'll work just fine.
Bill Burmeister
Use the appropriate size, otherwise its just the same.
•1952 Chevrolet 3800 pickup
---All pictures---
Its all about inside diameter. Brake lines have a thicker wall to withstand all that pressure. Fuel lines have a much thinner wall and greater cross section as they only see 5-10PSI on carbureted engines.
As long as the line lets the proper volume through (IIRC like a pint a minute.. its in the manuals). Since restrictions create pressure, you *might* have an issue with the pump not making enough pressure to push enough fuel to the carb. That's about all I can think of.
