4 members (JeffA, dt235sd, klhansen, UtahYork), 62 guests, and 3 robots.
Topics128,180
Posts1,057,160
Members48,464
I have two carter w-1 574S carbs ( 839987 ) that I want to put on my tattersfield dual intake.
Would anyone who has this setup mind telling me what modifications/issues they had with getting them working?
235 is stock.
Standard rear end, drive line, 4spd transmission.
Take care,
Steven
No one can drive us crazy unless we give them the keys.
Originally Posted by 52Stove
Was the 235 stock?
If you are asking about 1952, here is information about standard engines on various models.
Thanks Tim. But what I am looking for is information on how to setup the W-1. What jet size, needle and seat are needed? What are these long needles I keep seeing on ebay and what ones do i need for 574s (Chevrolet 839987? etc.....
Thanks for the help in advance
Take care,
Steven
Carburetion specialist
Here is a link which has much information about the W-1 carburetors:
http://www.thecarburetorshop.com/CarterChevroletW1.htm
Here is a link that has information about adjustmenets:
http://www.thecarburetorshop.com/Dual1barrelcarbs.htm
The "long needles" are the metering rods. The best approach is to build the W-1's to absolute stock condition; and then adjust from there. Depending on what has been done to the engine (compression, cam, headers, etc.) very little may be needed to modify the carburetors.
Jon.
The Carburetor Shop
Thanks carbking! Every thing is stock on the inside of the motor.
Can these be adjusted to handle a modified 261 ( step up cam, polished ports w 383 head ). I have purchased a few carter 966s in case the 574's will not work.....
Take care,
Steven
They should do fine on a 261 unless it is a dedicated race engine; in which case they may be a tad small. But if you are not at continuous WOT they should be fine. You will probably have to do a little tuning for the 261.
Jon.
The Carburetor Shop
Thank you Jon.
Take care,
Steven
