| | | Forums66 Topics128,095 Posts1,056,069 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 41 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 41 | Ok, starting a new thread as the frame issue is pretty well determined. As to my "big truck" gauges, I see in my 1964 owners guide that Chevy had two types; a simpler one for 1/2- 1 tons using tell-tale lights for temp, generator, oil pressure, brights and turn signals and a meter for fuel level and speedo. The other is for 1 1/2 - 2 1/2 tons with individual meters for temp, ammeter, oil pressure, and fuel level and speedo, and tell tales for turn signals, brights, tandem lock-out and overspeed plus an option for an air pressure and a tach meters. Now I've seen the latter in other C10's as well as mine mine so was this an factory option or simply a swap-out?
Brian | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | you could have either of the 2 just you would not have the tach or air gauge or vac gauge,in your truck, might have been a special order for the tach
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Warning lights or gauges, were available in the dash cluster of the '60-'66 Chevy light-duty (C10, C20, C30, K10 & K20), medium-duty (C40) & heavy-duty (C60 & C80) trucks. There are some other series of trucks like the LCF & titl-cabs, etc., but I don't recall precisely. The tachometer was optional, as well as a VAC gauge & AIR gauge. The Tandem Lock & Overspeed windows are in all of the dash clusters, in '64-'66 and I don't recall on the earlier '60-'63 models, off the to of my head.
| | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | The Tandem Lock & Overspeed windows are in all of the dash clusters, in '64-'66 and I don't recall on the earlier '60-'63 models, off the to of my head. Same true for '60 - '63, cluster with provision for Tac & Vac or air pressure gauge have Tandem Lock & Overspeed windows.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | | | |
