2 members (Gray_Ghost, 1 invisible),
238
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 34 New Guy | | New Guy Joined: Mar 2011 Posts: 34 | I am looking for a set of flywheel bolt locks for my 216, Anyone know where I could fine a set? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Some reproduction parts vendors sell bolts but they include star washers. Some people have recommended the star lock washers and a Loctite threadlocker.
Try posting a Parts Wanted ad in the Swap Meet.
Maybe someone will post a vendor that sells something like the original plates.
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You can always make yourself a new set. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | I did not use the factory bolt locks and opted to use blue "Loctite". Have been doing it this way since my first engine rebuild 35 year ago without any failures/issues. | | | | | Joined: Mar 2011 Posts: 34 New Guy | | New Guy Joined: Mar 2011 Posts: 34 | Thanks! I will just pick up some star washers and loctite them in. | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Can someone tell me when, in gereral, you would use a star washer as opposed to regular lock washer?
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Good question Dennis and I usually ask myself the same question. The answer I gave myself is a star washer when bolting sheet metal and split washer when bolting steel brackets or cast parts. Also, star washers are less susceptible to breaking, so I believe a star washer is a better choice for the flywheel even though it goes against my rules above. Also, the star washer is thinner and for the flywheel this might be important for clearance issues.
With that said, I don't see the need for any type of lock washer if using thread locker.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Dennis,
The main different is appearance is that the star washer is thinner. Maybe this, in combination with the thinner head on the bolt, are desirable in having less "head protrusion" on the surface of the flywheel.
An Internet search finds statements that there is much more "bite" contact area on a serrated/star washer than on the common split/spring lock washer.
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I would add that the heads on those flywheel bolts are thin for a reason, probably clearance. A split style lock washer would be thicker than the original flat washer with the bendable corners, possibly causing interference with the clutch assembly.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks for the answers guys. Learn something new every --- once in a while.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I would add that the heads on those flywheel bolts are thin for a reason, probably clearance. A split style lock washer would be thicker than the original flat washer with the bendable corners, possibly causing interference with the clutch assembly. Nail. Head.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | George,
That's the ticket.
What words do/did you use in the search on Ebay?
Thanks, | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Tim, Found these by going back to sellers that, I previously bought vintage GM NOS parts from. Seems that the one's that I bought from before keep finding more nos parts. This seller has slowed down some in the last year or so.
If I were to search...I'd search:Flywheel Locks.
The number thats on the box: 136857
If that's a valid GM part #.
Seacoast Chevrolet in Wannamassa, NJ has ( 64 ) of them. Seacoast is only ( 4 ) miles from me. There phone # is: 732-918-1100 .
Tim, send them my photo to see if it's the same part they have in stock.
Let everyone know how you make out.
George in New Jersey
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Wish I had the time and my machines set up. I only made enough for a few engines when I made these for my 216 rebuild: http://www.pbase.com/dennygraham/image/128167897
Denny G Sandwich, IL
| | | | | Joined: Oct 2012 Posts: 7 New Guy | | New Guy Joined: Oct 2012 Posts: 7 | DennisM Today I installed my flywheel on my (41 Chevy truck AK)216 motor using Chevys of the 40s part # 839756 flywheel bolt kit. It came complete with all grade 8 bolts c/w star washers.( about $10.00 set) I installed using thread locker and was really pleased with the quality. good luck with your project. Mur41 | | |
